Hey Guys,
When you do concrete wall opening reinforcement, do you extend it all the way to the ends of the wall? Or do you just extend enough past the opening to develop it into where it needs to go? For example if I have openings with a "beam" of horizontal reinforcement below, can I just extend it enough into the beam to develop? I know it works load path wise as long as the beam is designed for it, but what about constructability? Is this typical to do or do you typically spec it to go full length?
Thank you!
Thank you!
