lotus7312
Chemical
- May 29, 2003
- 24
If there are two reactors heated up by steam. The steam header pressure is same, say 6 bar. But the two reactors need different steam pressure due to the different process(say reactor 1 needs 5bar which reactor 2 needs 1bar). Therefore, the inlet steam pressure is regulated by cracking the isolation valves in the steam line. Can I send condensate from these two reactors back to boiler if I connect the two condensate return line from these two reactors together? If not, is there any way to solve this problem?
