conect node of element CIRCU124 with SOLID231
jorand
Computer
CO
I have two element: the CIRCU124 and SOLID231.
I have a block de 50*50*13 cm, I apply the mesh, after I want apply the Voltage, but with the circuit using the element CIRCU124. How conect the node of CIRCU124 with nodes created in the block (this use SOLID231)?
Hi Jorand
first you have to coupling nodes in some area that you want then you have to choose a node (inside) and apply the voltage, obviouly, in order to have a voltage in the block in other area of this block you have to apply a 0 voltage
I hope you can undestand my bad english
Lucky
