n3jc
- Nov 7, 2016
- 189
Im dealing with an outer staircase which leads to basement. There is a concrete wall that is enabling this. What is a normal/usual connection between the wall and staircase?
The wall has to be build first I guess since it enables a room to even build staircase?
But after the concrete wall is standing is there any connection between staircase and wall? (dowels/rebar from the wall to the staircase) or nothing (i think some cracking will apear).
Maybe some thin (1 cm) thermal insulation as dilatation between?
Thoughts?
Thoughts?
