Connection to X-mas tree 3
snMartin
Petroleum
Oct 22, 2009
8
We need to buy a forged flange adaptor to connect to the X-mas tree.
This forge flange adaptor has the following ends
- End 1: 3" ansi/asme B16.5 flange class 2500#
- End 2: 4-1/16" API 6B flange 5ksi
And this flange adaptor shall withstand 6500 psi
Has anyone bought these kind of flange adaptor? what would it be the design code? ASME VIII??
Thanks in advance
See B31.3, .4, or .8, if applicable to the components tying on (downstream) to the tree, or the company's design spec for well head assemblies. Use whichever design reference the applicable design code specifys for flange design.
Let your acquaintances be many, but your advisors one in a thousand’ ... Book of Ecclesiasticus
You are crossing the line...... between API materials and code and ASTM materials and ASME/ANSI code. Lucky you don't have a 15k or 20k+ tree. I recommended a spool with API on one end and ANSI flange on the other; I think this has been posted before so you may find other possibilites.
Checkout the Wood Company's Spool Adapters. There are several ways to address your problem so it would be better to contact them with all your requirements and information needed to get the proper component.
There is a lot of information on this site and to get to some of it you have to register.
Thank you for your answers.
It seems that we are going to make some calculations as per ASME VIII Div.2 part 5.
Unclesyd thanks for the link, that page is awesome
Hello jbeckhou
It is the design pressure, it is not going to be the test pressure nor the working pressure.
