BigHarvey
Geotechnical
- Jan 7, 2003
- 403
As a court expert I have a case where I believe damages have been caused by construction vibrations (rock removal or micropile drilling with DTH hammer at 6 m from structure). I am looking for data about vibrations (PPV) caused by thes two construction activities. I attach a picture of the most damaged colums (sandstone with UCS of less than 25 MPa). I don't see any other explanation since loads have not changed, damages are less consequent with distance, stone is porous and weather is mild (and columns are from 1890 !). Your dataa and advice is appreciated !
