contact between an irregular cylinder and 2 plates PLEASE!!!
carolina000
Bioengineer
Sep 28, 2009
19
Dear all,
I'm trying to model contact in the following case:
an irregular cylinder, 2 parallel plates, one on top and one below the cylinder; the one below has 0 displacements prescribed and the one on top is subject to a traction force; the edge of the cylinder is encastred (to the wall perpendicular to the plates).
Following suggestions in this forum I have "nudged" the plates to the highest and lowest nodes in the cylinder respectively.
The crazy thing is CSTATUS shows all the nodes in the surface of the cylinder are closed, CPRESS is 0 everywhere and COPEN shows very small values in the bottom and 10 orders or magnitude higher in the top of the cylinder surf. Besides the dat file does not say there are 3 or 2 unconnected regions.
A bit more about the model:
I've set two surface-to-surface contact interactions, one between the surface of the cylinder and the top plate and the other with the bottom plate.
For some reason i can use clearance=0 and adjustment to the top interaction while, if i use clearance=0 and adjustment to the bottom interaction, in the analysis all the nodes try to move to the top plate and I get 0 volumes.
Im not an Abaqus expert (you know that already, right?) but it seems all the nodes are trying to contact/move towards the bottom plate.
When i made the preliminary tests the model worked even to 70% of the displacement and now i cant make it work any more, not even one increment and IM DESPERATE!
Any ideas on how to fix this and make Abaqus set contact of nodes on the top with the top plate and the ones in the bottom to the top plate? Please, please, please?
Thank you so much in advance,
Carolina
I would break the problem into 2 parts.
1. figure out how to get a similar representative model to solve efficiently. Modeling 1 quarter of 1 cylinder will greatly increase turnover time.
2. figure out how to get a nicer mesh from your scan data.
Once you have both of these solved apply the methods from 1 on 2.
I hope this helps.
Rob Stupplebeen
If you are trying to simulate the real thing, Rob's model is probably more accurate than your scan.
