JohnSerkaian
Automotive
- Aug 21, 2006
- 2
I've got general questions regarding front suspension control arm geometry and I'll do my best to clearly explain them: Ideally, one would assume that the pivot axis of the front control arms would be somewhat parallel to the longitudinal axis of the vehicle. (At least that's what much of the research assumes.) Vertical adjustments would be used to manipulate anti-dive characteristics but the axis of the arms, looking down from the top of the vehicle, would have the pivot axis parallel to the vehicle axis. However, some of my vehicles splay the horizontal pivot axis so much it doesn't seem to make much sense from a geometry standpoint. Two of my post-war vehicles splay the arms in a semi-trailing arm fashion so the tie rods work off centered pivots just behind the lower control arms. (The center pivot is properly positioned at the intersection of the LCA pivot axis. Typical examples - 1961 Corvette w/kingpins, 1955 Thunderbird w/ball joints.) My late model GM vehicles with front-steer steering systems use lower control arms with the rear pivot points splayed outward - opposite of the trailing arm approach of the post WWII geometry. (It almost seems like GM tossed out "proper" geometry to make plenty of room for their clunky starter motors and exhaust pipe routings.) Two examples were my 1977 Caprice and 1978 Firebird (same suspensions) which rode and handled fine in a variety of street and track driving conditions. So.... What are the reasons early IFS systems splayed the control arms in a semi-trailing fashion and why did GM go to the other extreme with some of their modern IFS systems? I can see some possible logic behind the trailing-arm concept for reduced ride harshness but I can't see how any deviation from a parallel axis could improve handling. Anyone out there that can shed some more light on this topic? Thank you.
