I have two(2) 1000-ton centrifugal chillers and four(4)variable-speed pumps sending 39 deg F chilled water to the primary side of eight(8) plate and frame heat exchangers. My customer circulates water on the other (secondary) side of the heat exchangers. My obligation is to hold 42 degress F on the secondary outlet water.
I also have control valves I can modulate on the chilled water supply to the heat exchangers.
Every control scheme we try oscillates. We get a periodic swing of several degrees (period = 3 minutes) when the thermal load at the heat exchanger is steady.
Any suggestions on how to control this beast? Thanks.
