I know that if we have a pump connected to a pipe which have a control valve ,as we change the opening of the valve , the resistance of the system decreases or increases and the pump moves on its curve and the flow rate from the pump itself changes , so the control valve controls the flowrate in indirect way as it changes the resistances in the pump way and the pump is the device that changes flowrate.... An enginner once told me that the control valve itself changes the flow rate , for example if we install a glope valve and open it at certain opening the flow rate upstream valve is 20 m3/h and the flowrate downstram the valve is 10m3/h ,, is what he said is right ? i guess that what enters the valve must get out of it , if 20m3/h enters the valve , the 20m3/h must get out of it otherwise where they goes ?
