I want to control the position of a cross hole on a cylinder.
The tolerance zone I want to create is 2 parallel planes .030" apart (see the blue in the image attached). Basically, I want to make sure the hole goes through the center of the cylinder, but I want to give manufacturing as much tolerance to position that hole left or right.
How do I construct my FCF to control just the position of the thru hole through the center of the cylinder without limiting the location of the hole left or right? Is the drawing I have attached correct?
