convert damping values in frequency domain to transient damping (generalized maxwell model)
engsea
I have the individual damping values ( kN.s/mm ) / frequency for an isolator pad used in a vibro-hammer.
For the steady state solutions the isolator is modeled as a spring in parallel with a dashpot with the correct damping for the frequency under consideration.
The non-linear damping in the initial startup of the system ( transient case ) can not be specified per frequency.
After going through some theory about viscoelasticity the idea is now to model the time domain damping as a generalized maxwell model.
However most of the papers are dealing with FEM viscoelastic material models ( storage modulus , loss modulus prony series ).
I'm not using FEM and just need the ( time domain equivalent ) generalized maxwell model parameters based on the given frequency damping values of the isolator pad.
Is it a good idea trying to implement non linear damping in the time domain by means of a generalized maxwell model of springs and dashpots, or am I on the wrong track ?
I would appreciate some help or links to websites, papers .. anything what can help me to estimate the parameters of the springs/dashpots based on the provided damping/freq values.
Indeed new here.
I'm not a student writing a thesis or so, I have 35+ years experience in pressure vessel and structural calculations and knew this forum from my past as a pressure vessel designer.
This is the first time that I have a vibrohammer hanging in a structure and need to find a way to derive equivalent 'static' design loads for use in my expertise domain, structural design.
After some googling/studying, viscoelasticity and generalized maxwell model seemed the best option for the frequency dependent damping in the time domain.
Searching for viscoelasticity on eng-tips lead me to this forum.
I'm not a specialist in vibration or acoustics and apologies if this post does not belong here and will try to close or delete it.
( BTW thanks for your answer, it's the same as what I was trying to do but then for an N-order maxwell model. )
There's nothing wrong with the thread, that's just my sig
I'm not sure a simple Maxwell model is appropriate for a typical impact hammer, the tips I used were rubber, nylon or steel, or whatever else came to hand (I have used plasticene or black duct tape if I couldn't find the extra mass that screwed on the hammer head). With the usual setup for a modal analysis you don't need to model the tip.
For rubber and foam and probably nylon I'd use a multi Maxwell type model, with an undamped spring as one of the parallel elements being the main stiffness. ie 2 branches, one is a spring, one is a spring and damper in series. This is similar to a vehicle suspension, in layout.
There are more complex models, but I haven't used them. I think we used a Hammerstein model for foam as in jounce bumpers, but I never set one up.
Cheers
Greg Locock
