142846
Chemical
- Jul 13, 2020
- 107
How to convert dwg file to searchable pdf file?
thanks for any respond
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
I need searchable pdf file because for example I want to know how many "psv" text is in the one pdf file.And what do you want to search for ?
unfortunately autocad default settings dose not produce a searchable PDF. I tryed some settings/Options in the printer setup and could not have searchble pdf. for this reason I raised this question. only pdf to dwg.pc3 produce searchable pdf, but cad text are in the comments of pdf files.default settings produce a searchable PDF
I am not good on cad. Is it possible say how can I do this setting.CarlB (Civil/Environmental)
Hello, I did Your solution, but the output is a nonsearchable pdf file. my question is:IFRs (Petroleum)
I couldn't find any useful subject in this adress.
shame for what!? or for who!?3DDave (Aerospace)
you are right. thanks for your perfect attention and sorry (espacially from 3DDave) for any misunderastanding. I will try improve my english.I'm guessing English is your second language?
Autodesk Autocad 2018Again - WHAT VERSION OF AUTOCAD ARE YOU USING?
