BruceAus
- Jun 30, 2011
- 2
I'm working on a pedestrian bridge that have some 20,000 rivets of which 10% are corroded. The corroded rivets range from no head left to only a small amount of head missing. It is easy to decide what to do with those both ends of the spectrum, but how do I decided when where is the point where to much corrosion has occurred.
Does anyone have any guidelines on determining when a rivet should be replaced?
The next issue is a quick method to determine if a rivet passes or fails the guideline. I was thinking of some type of templates that you place over the rivet but as there are so many different possibility I not sure this would work. Anyone got any bright ideas on how this could be done?
