Josef M.
- Sep 16, 2024
- 5
I'm working on a project that involves using a huge carbon steel buffer tank in a stainless steel piping system (close water chiller system). I'm concerned about potential corrosion issues that could arise from this combination.
Has anyone here had experience with a similar setup? If so, what precautions or measures did you take to prevent corrosion and ensure the system's longevity?
What measures should we take to avoid corrosion on a 30 year lifespan? (coat the inside, air vent valves, corrions inhibitors,...)
