CosmosWorks 2003 Thin Plate Analysis 1
Paulhen
Industrial
Jun 2, 2004
1
I have recently done an analysis using CosmosWorks 2003 on a 24"x36"x0.018" (26 ga.) plate that is fixed on all 4 edges with a 0.46 psi pressure on the face and is 304 SSTL. I used the mid-surface mesh type with a pretty fine mesh size. The results were very surprising. Cosmos calculated a max deflection of 23" and a max stress of 3.28x10^6 psi (ultimate for 304 is 75000psi per Cosmos). This just seems wrong(24"x30" plate physically tested at 0.36" deflection).
Why is Cosmos producing such a result and is they a way to properly analyze this scenario?
Small Deflection Theory vs Large deflection Theory of Plates???
Any ideas would be helpful.
Thanks Neil
You may want to direct this query to the Finite Element Analysis Engineering forum. Sounds like more of a general FEA question than a COSMOS question.
<forum727>
[bat]Due to illness, the part of The Tick will be played by... The Tick.[bat]
Yeah, it is because the plate is a large deflection case. I recently did an FEA using cosmos for a thin film, .0005 thick. It was clamped on all four edges. Under a very small pressure 1X10^-4 psi, it deflected some odd 2000 in. Ha Ha. Interestingly enough, this matched the hand calc. When I used an equation that takes into consideration the "membrane" properties of the system, (essentially the non-linear aspects of the problem), the deflection was on the order of .25 in.
In order to properly do your problem in FEA, you must have the non-linear package. For the equations that will help you do this as a hand calc, do a google search for "Timoshenko plate large deflection"
