COSMOSXpress Stress Analysis of Weldment
ibro
6
I want to do a stress analysis of weldment with COSMOSXpress. It seems that COSMOSXpress works only with part not with weldment. Any workaround? Is there way to "convert" weldment to one solid part? I am using SW2006.
Thanks,
Ibro V.
No work around that I'm aware of....COSMOSXpress is an introductory version of COSMOSWorks. Check you online help for what you can do in CE. I think you will need to have the Cosmos Professional to be able to do weldments because I believe it treats them as assemblies. I could be wrong on that because we use a different analysis program.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"Coming together is a beginning, staying together is progress, and working together is success." - Henry Ford
How about doing a Combine on the Cut List bodies? Not exactly the same as a weldment, but maybe close enough.
[cheers]
Helpful SW websites faq559-520
How to get answers to your SW questions faq559-1091
Blimey is correct in saying that while you cannot use cosxpress on an assembly or a multi-body part, you can combine the individual bodies into a single entitiy and run the analysis like that.
The one major problem with this method that "contact" areas will become solid, as if the part were welded with 100% penetration and no weld re-inforcement (the bead) and this would certainly be misleading as to the actual strength of the weldment.
Another method i have used in the past is to actually model the welds complete with penetration profile, and crown. In areas where necessary i have also modeled the melt through (such as the root pass of a v-butt weld).
You can use any method that you wish to model the beads, just make sure that you re-select the "merge result" option in the property manager.
Oh i should mention that if there are faces in the members of a weldment that touch, they too will join when using this method so you may want to cut-a little material so there is a small gap before you start modeling weld beads.
Just another option.
Best of luck
Jon
