  • Congratulations Toost on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Could please anybody help me too open the file..........error 410
The file appears to have a lot of damage. The error message indicates the first error that was encountered. If you right-click the file and select Edit you can manually remove or correct the damaged sections. However, there is a lot of damage, so you may be better off going to a backup or an earlier version of the file. I would also be concerned about whether the damage was caused by a system problem, such as a failing hard drive. This type of damage is not common, and definitely indicates some kind of system problem. (Or someone has been editing the file by hand and damaged the data structure!)
Peter Smart
HydroCAD Software
Thank you, Peter! So appreciate your time and efforts.
Unfortunately, I don't know how to remove or correct damaged sections, we are not programmers.
And we don't have backup files also :(
Is it possible to know "the system problem"? How to fix it?
We reinstalled the program recently, but the same mistake occurs again and again with different files. We can't find anything wrong.
I attached different files with the same problem
Thank you for your time!
 https://files.engineering.com/getfile.aspx?folder=f19f3ec2-c320-4712-9249-b1fa204c9297&file=7577-14_5906_AMARAL_RD.hcp
The error message tells you exactly what the problem is. For example, here is one of the errors:
Error 410: Cannot load file
Unknown item:
ber=9P
in Pond 10P
And here is the corresponding portion of the project file:
[NODE]
Number=10P
Type=Pond
Name=PROPOSED TOTAL DISCHARGE
XYPos=0.125276572601079 1.9630041655851
Message=[40] Hint: Not Described (Outflow=Inflow)
ber=9P ********** this should be "Number=9P" ***********
Type=Pond
Name=EXISTING DISCHARGE
XYPos=0.108910891089109 6.35643564356436
Message=[40] Hint: Not Described (Outflow=Inflow) here is part of your damaged file:
I've marked the line with missing characters. Unfortunately several other lines also seem to be missing before this. All of your errors are similar. As I said before, this suggests a problem with your computer or file system. There is nothing wrong with HydroCAD. But when the files are being opened there is data missing, which indicates a problem with your computer.
Try another PC and you will find that everything works fine.
Peter Smart
HydroCAD Software
