I've recently designed some soldier pile/ concrete sleeper retaining walls using Brom's method.
Using Coulombs equation for passive pressure and allowing for a wall friction angle of 0.5*Phi gives a much higher kp value than Rankine's.
Based on a previous topic Here
I gathered allowing for wall friction is okay as long as it is done in moderation.
Using above method gives a kp of around 4.2 for a phi = 30. These parameters give a pier depth of around 2.1m for a wall height of 2.0m with 1.6m pier spacing.
I was hoping to get some advice on the depth of the footing from those experienced in soldier pile walls.
Any advice/ recommended resources is greatly appreciated.
