jnmaney
- Aug 18, 2005
- 24
I have a system i want to get some advice on. Large milling machine, hyd system = counterbalance circuit : 2 counterbalance cylinders, pilot operated check valve, pressure reducing valve and a nitrogen charged accumulator. 1 additional pressure line going out to 1 other area of machine. My experience with this system is when hydraulics are shut off pump pressure immediatly drops to zero and counterbalance gage does not drop, holding system pressure for that circuit at the check valve. What I have on this machine is pressure is maintained at the pump for a couple seconds after pump is shut off, then a noise like fluid rushing back reversing the pump. Hyd gage drops to zero. C/bal gage also drops to zero, then quickly return's to system pressure. Is a brand new machine, have replaced the pilot operated check valve and the pressure reducing valve. Initially with the original components the c/bal pressure was slow to creep back up to system pressure after shut down, now with new valves = quicker response to system pressure.
See other replys to thread at
javascriptpenindex(450,450,'
