cyphos168
- Feb 25, 2016
- 37
Hi all,
Need some advice on crack width requirement for swimming pool structure. The pool is located on an upper floor level. Some literature state crack width of 0.1 and 0,2 depending on the length of water tightness tests to be conducted. SO I am assuming 0.2mm being the limit of crack that is allowed to form in the structure. Is this limit set based on normal concrete or with waterproofing membrane in place? I would have thought if a waterproofing membrane is going to be used to line the pool, crack width limit would be higher but not too high as to cause the lining to fail. Thanks.
Chong
Chong
