create Enviroments for use catia v6 with two monitor
jakissimo
Marine/Ocean
Aug 21, 2015
5
hi all
I need to use two monitors with catia I read that you can 'create an environments to do this. some have the procedure or an example to understand? thank you
Marco
where?
I have 2 screens and I use 3DX2014x no special catia env here. I use V5R24 the same way.
I manage my screens with windows option and/or nvidia panel
Eric N.
I found a thread of 28 February 2005
I need to have the window of catia on both monitors at the same time but not a clone but use the command multiview catia, for example on a monitor the top view and in the view of the front? can be done ?
you can link a thread by just typing (or copy paste) its number like (with no space) t h r e a d 5 6 0 - 3 9 3 5 5 1
this will provide a link to thread560-393551
That said: you can "extend" your screen to monitor 2, not duplicate it.This is done in windows.
Multiview will not adapt to multi screen, thatss why you need to have same resolution on both monitor so the vertical split is in the middle.
if monitor have same resolution it should work. What is your problem?
Kinda work for me but screen res are not he same so I have line split for vertical on 1/4 of screen 2.
Eric N.
