  • Congratulations Danlap on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Create Hole From Projected Line or Existing Hole
BrittToolEngineer
Aerospace
Aug 4, 2016
239
Greetings,
From NX12 and prior, I was always able to create a hole, either threaded or whatever, from a projected circle or even from the bottom of a clearance hole of a body that was directly on top of another body. Now when I attempt either of those in NX 1926, after clicking the hole command, neither the hole next to the surface I wish to select nor the projected circle will allow me to actually select it. Is there a setting that I'm missing here?
Thanks,
Brent
Also, I just noticed. I created a sketch to make the first set of holes (and like I said before, I usually could use those holes to create the holes in the next body), the sketch geometry allows me to select; however, the projected geometry does not. hmmmmm ????
Some more information, the hole command will recognized body features and sketch features, but not a projected circle?
Is that projected object a real circle or does it only look like one and the geometry is a spline ?
( select the curve & Ctrl+I , the listing window will tell what type of geometry it is.)
I tried projecting a circle in NX1953 , then hole and selected the projected circle center as position, no problem.
Tomas
Never try discuss with a fanatic, it wastes your time and it annoys the pig.:)
I just learned from one of the NX trainers that the new version has a new feature called "Project Point onto Target". They are trying to reduce or eliminate users from having to project geometry to create holes.
