  • Congratulations Danlap on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Creating a pattern in an Assy without a hole pattern
garmancm
16
I use Inventor quite a bit, and in that you can create a pattern that you could select a part, let's say a support beam between two parts... and tell it to pattern that beam 10 times, with 20mm in between each one.
Is this possible in Edge? I know you can pattern things like hardware to holes, but that's not what I'm trying to do.
I believe you can do this using a sketch as the 'part containing the pattern'. Or maybe the sketch has to be in a sub part - sorry I think I've done this once or twice but not recently.
An assembly level sketch will work as the pattern definition.
