I'm trying to create a cartoon for visual editor in the drafting application that has expressions associated with it. According to the NX documentation I need to set the environment variable UGII_DRAFT_EXPRESSIONS_OK=1. I did just that, but the VE is still not accessible in the drafting application. I ran help>NX Log File to make sure I made the change in the proper directory, and ugii_env.dat file. I'm using NX6.
Does anyone have suggestions, or a possible work around?
Thanks.
Thanks.
