Tinni1
- Sep 27, 2021
- 157
I am trying to create the bolt pretension load in the Abaqus explicit solver.
Since, the bolt load, that is available in the static general solver is not available in the explicit solver, I am trying to create the bolt pretension using a temperature gradient(Based on guidance provided in the literature)to create an equivalent amount of loading, as that in pretension.
My questions are below:
To apply the temperature load, I need a surface, which I presume should be the inner circular surface of the bolt shank at the mid-length of the bolt, as I have seen in the bolt load case in a static general solver. In the part module, I have defined this surface. But while applying the temperature load, I am not able to select this inner surface. I am only able to select the outer perimeter of this surface.
Could anyone please advise how I apply this temperature gradient on the bolt? Should it be on the inner circular surface at the bolt shank mid-length or on the outer periphery of this surface, or on the entire outer surface of the bolt shank?
If it is on the inner circular surface at the bolt shank mid-length, how do I select this surface on the load module in Abaqus?
Many thanks!
Many thanks!
