Creating wavelinks problem
javaxp
Automotive
Jul 14, 2014
43
I intend to make a journal that makes a new component containing all the bodies in Layer 1 from all components. (This is a simple aproximation of real thing)
Firstly I cycle all components in assembly, collecting for each component the bodies in layer 1 and creating a List (Of Body) with these objects (waveList).
Then I create a new component and set it as workPart.(test.prt)
Finally, I try to make the wave links with waveLinkBuilder using the list of bodies but this gives me an error: "Can't create the wavelink feature because the object selected is into the workPart"
The code:
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Assemblies
Imports System.Collections.Generic
Module NXJournal
    Public theSession As Session = Session.GetSession()
    Public ufs As UFSession = UFSession.GetUFSession()
    Public lw As ListingWindow = theSession.ListingWindow
    Dim waveList As New List(Of Body)
    Dim workPart As Part = theSession.Parts.Work
    Dim dispPart As Part = theSession.Parts.Display
    Sub Main()
        lw.Open()
        Try
            Dim c As ComponentAssembly = dispPart.ComponentAssembly
            'to process the work part rather than the display part,
            '  comment the previous line and uncomment the following line
            'Dim c As ComponentAssembly = workPart.ComponentAssembly
            If Not IsNothing(c.RootComponent) Then
                '*** insert code to process 'root component' (assembly file)
                'lw.WriteLine("Assembly: " & c.RootComponent.DisplayName)
                'lw.WriteLine(" + Active Arrangement: " & c.ActiveArrangement.Name)
                '*** end of code to process root component
                reportComponentChildren(c.RootComponent, 0)
            Else
                '*** insert code to process piece part
                lw.WriteLine("Part has no components")
            End If
        Catch e As Exception
            theSession.ListingWindow.WriteLine("Failed: " & e.ToString)
        End Try
        createComponent()
        addWave(waveList)
    End Sub
    Sub reportComponentChildren(ByVal comp As Component,
        ByVal indent As Integer)
        For Each child As Component In comp.GetChildren()
            '*** insert code to process component or subassembly
            'lw.WriteLine(New String(" ", indent * 2) & child.DisplayName())
            '*** end of code to process component or subassembly
            If child.GetChildren.Length <> 0 Then
                '*** this is a subassembly, add code specific to subassemblies
                '*** end of code to process subassembly
            Else
                'this component has no children (it is a leaf node)
                'add any code specific to bottom level components
                Dim myPart As Part
                myPart = child.Prototype
                For Each myObj As Body In myPart.Bodies
                    If myObj.Layer = 1 Then
                        waveList.Add(myObj)
                    Else
                    End If
                Next
            End If
            reportComponentChildren(child, indent + 1)
        Next
    End Sub
    Function createComponent()
        Dim FileName As String = "c:\temp\test.prt"
        Dim newName As String = FileName
        Dim fileNew1 As NXOpen.FileNew = Nothing
        fileNew1 = theSession.Parts.FileNew()
        fileNew1.TemplateFileName = "Ekide_model-plain-1-mm-template.prt"
        fileNew1.UseBlankTemplate = False
        fileNew1.ApplicationName = "ModelTemplate"
        fileNew1.Units = NXOpen.Part.Units.Millimeters
        fileNew1.RelationType = ""
        fileNew1.UsesMasterModel = "No"
        fileNew1.TemplateType = NXOpen.FileNewTemplateType.Item
        fileNew1.TemplatePresentationName = "Plantilla_model"
        fileNew1.ItemType = ""
        fileNew1.Specialization = ""
        fileNew1.SetCanCreateAltrep(False)
        fileNew1.NewFileName = FileName
        fileNew1.MasterFileName = ""
        fileNew1.MakeDisplayedPart = False
        fileNew1.DisplayPartOption = NXOpen.DisplayPartOption.AllowAdditional
        Dim createNewComponentBuilder1 As NXOpen.Assemblies.CreateNewComponentBuilder = Nothing
        createNewComponentBuilder1 = workPart.AssemblyManager.CreateNewComponentBuilder()
        createNewComponentBuilder1.ReferenceSetName = "MODEL"
        createNewComponentBuilder1.LayerOption = NXOpen.Assemblies.CreateNewComponentBuilder.ComponentLayerOptionType.Original
        createNewComponentBuilder1.ComponentOrigin = NXOpen.Assemblies.CreateNewComponentBuilder.ComponentOriginType.Absolute
        createNewComponentBuilder1.OriginalObjectsDeleted = False
        createNewComponentBuilder1.DefiningObjectsAdded = False
        createNewComponentBuilder1.NewComponentName = "test"
        createNewComponentBuilder1.NewFile = fileNew1
        Dim nXObject1 As NXOpen.NXObject = Nothing
        nXObject1 = createNewComponentBuilder1.Commit()
        createNewComponentBuilder1.Destroy()
        Dim partLoadStatus1 As NXOpen.PartLoadStatus = Nothing
        theSession.Parts.SetWorkComponent(nXObject1, NXOpen.PartCollection.RefsetOption.Entire, NXOpen.PartCollection.WorkComponentOption.Given, partLoadStatus1)
    End Function
    Function addWave(ByRef waveList As List(Of Body))
        Dim nullFeatures_Feature As Features.Feature = Nothing
        workPart = theSession.Parts.Work
        Dim waveLinkBuilder1 As Features.WaveLinkBuilder
        waveLinkBuilder1 = workPart.BaseFeatures.CreateWaveLinkBuilder(nullFeatures_Feature)
        Dim extractFaceBuilder1 As Features.ExtractFaceBuilder
        extractFaceBuilder1 = waveLinkBuilder1.ExtractFaceBuilder
        extractFaceBuilder1.FaceOption = Features.ExtractFaceBuilder.FaceOptionType.FaceChain
        waveLinkBuilder1.Type = Features.WaveLinkBuilder.Types.BodyLink
        waveLinkBuilder1.CopyThreads = False
        extractFaceBuilder1.ParentPart = Features.ExtractFaceBuilder.ParentPartType.OtherPart
        extractFaceBuilder1.Associative = True
        extractFaceBuilder1.FixAtCurrentTimestamp = False
        extractFaceBuilder1.HideOriginal = False
        extractFaceBuilder1.InheritDisplayProperties = False
        Dim selectObjectList1 As SelectObjectList
        selectObjectList1 = extractFaceBuilder1.BodyToExtract
        extractFaceBuilder1.CopyThreads = False
        Dim added1 As Boolean
        added1 = selectObjectList1.Add(waveList.ToArray)
        Dim nXObject1 As NXObject
        nXObject1 = waveLinkBuilder1.Commit()
        waveLinkBuilder1.Destroy()
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        Return Session.LibraryUnloadOption.Immediately
    End Function
End Module
Any hint to solve the situation?
Javi
NX 12.0.2.9 MP14
The "waveList" is collecting the prototype bodies from the various component parts; however, to create wave links, you need to select the occurrence bodies from (in your case) the top level assembly.
www.nxjournaling.com
Hi cowski,
Yes, that was the problem. Now, for selecting the bodies I use the function AskAllBodies related on Link that recopiles the occurrences.
Thanks cowski.
Javi
NX 12.0.2.9 MP14
