Critical Load in Column
Michael Andreas
1
Halo, I'm trying to define critical load in short column.
There are 3 types of short column that I'm trying to define, plain concrete column, steel-reinforced concrete column, and composite column with I-profile steel. Each type has two different height; 20cm and 60cm. So, there is 6 short columns in total.
How do I define these 6 columns using sap2000 to get the maximum load/critical load that the column can bear? Do I use 3D frame or solid model?
I'm hoping someone would help. Big thanks
use frame elements, if you could use section designer it's more convenient
Shoot for the Moon, even if U miss, U still land among Stars!
