jacquelinev
- May 5, 2009
- 5
Does a drastic phase angle change always indicate a critical speed? (but vibration amplitude stays relatively constant during a decel)
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
I see phase change of 180 degrees at 4khz corresponding to single pole and phase change in opposite direction of 180 degrees at 9khz corresponding to single zero. Can you explain why you think it resembles double pole or double zero?If you believe the phase data , it looks like a double pole at 4Khz ( resonance) with light damping going to 180 almost to 8Khz but the problem is you cannot simultaneously show no gain change when in fact there should be a drop of 40 db/ decade.
At 9 Khz there is a definite double zero ( certainly not resonance)
Could be that a speed squared forcing function contributes toward this? (as frequency increases towards infinity, the response should grow without bound, unless there are two more zero's than poles in the transfer function).and the behaviour of the gain is in the right direction but strangely high.
