Dear Specialists ,
Doing some consultancy LNG terminal and LNG Shipbuilding.
I am looking for an answer/guidance about minimum requirement to consider a ball valves to be fire safe or not.
My focus will be on valves having a size below 8” inches as everyone know that for valves having a larger size (more mass) the actual Fire safe test is not relevant as energy for heating the body will “not” affect the trim due insufficient allowed burning time according the code EN ISO 10497, API 607, API 6FA.
As mechanical engineer it obvious for me that the valves to have at the minimum the some clear feature to pretend succeeding the test.
For example one of the candidate supplier present his valves “Ball valves Top entry” as fire safe however the seat arrangement “piston type “ is equipped with fragile lip seal in PCTFE or modified PTFE.
It is clear that those lip seal alone will not hold for long at elevated temperature.
Some other supplier have Graphite ring as backup which seemed more appropriate.
Any though on this ?
Tory
Tory
