bjeservice
Dear friends
i tried to built an electronic control circuit for earth fault protection, so i built a current transformer with the information listed below ( as i know some informations of how to built them ). the current transformer load is 200 ohm resistive, the voltage that i need to deal with is 1.00 volt as the fault current of the transformer is 3.00 Amps in primary so what i need is 5.00 mA in secondary coil.
inner iron diameter of toroidal ct = 318 mm
outer iron diameter=338 mm
width of iron sheet=25 mm
the iron sheet is grain oriented silicon steel and it is heat treated
the coil is 600 turn coil, of 0.25 mm bare wire diameter and wound uniform around the iron core, its resistance is 21.0 ohm.
The problem is :i could not get the 1.00 volt from the 200 ohm load , only a 0.70 volt i get and any winding correction get no use.
could any one inform me why i could not get the one volt from the 200 ohm .
