Cursorily Review of Concrete Details
Tim_Crouse
Would someone involved in daily RC Concrete design mind looking over an equipment slab I setup.
In summary, the pad is an equipment pad designed to accommodate (3) uniform wall loads of approx 450 LBS/FT.
The equipment is a chiller skid weighing approximately 17,000 LBS with the pad sized to accept (2) future units.
I designed the PAD using the PCA (basically the slab on grade subject to heavy load document) method and double-checked it with the Gradslab spreadsheet (the slab on grade spreadsheet from the website).
Any feedback is welcome.
Thanks in advance
-Tim C.
 https://files.engineering.com/getfile.aspx?folder=c8bf854c-f266-4beb-a33d-cbb9bc6605c6&file=Project_Concrete_Equipment_Slab_Details.zip
dik, what is the reentrant detail?
Sent From My TI-84+
It's the inside corner for an 'L' shaped slab. I'm not sure for that one, but the insertion point for the block was the inside corner of concrete.
