Dear all
Can anyone tell me which curve fit is the best fit to use when working with head versus flow rate data and head versus efficiency data on centrifugal slurry pumps with a low specific speed (100-700 or so)?
I am a Mechanical Engineer fresh out of university and am currently working for a slurry pump manufacturing company.
One of the projects I have been assigned is to help fix up pump selection software that the company currently employees in producing sales quotes. In its current form, the software tends to misquote on certain efficiency and %QBEP values when working with certain pump curves.
I believe that part of the problem lies with the way the software plots a curve through the pump input data it is given. Currently the software will accept 7 data points per speed setting (since these are slurry pumps, the impellers are not trimmed but rather belts are used to adjust the pump speeds). The data points inputted per speed setting consist of the following:
7 flow rate values
7 corresponding head values
7 corresponding efficiency values
Once these data points have been entered into the program it plots a 4th order polynomial through the data and generates curves of head versus flow rate and efficiency versus flow rate.
I have contested that plotting a 4th order polynomial through the data does not make the generated curves more accurate. I cannot remember from theory where I saw 4th order terms in any pumping related equations. I argue that a 2nd order curve is far more likely to represent the statistically most likely value of either head or efficiency that a customer may obtain for a given flow rate should they test the pump, even though the actual data points inputted into the program deviate from the curve more than they would for a 4th order curve.
Thus I recommended a 2nd order curve fit for both head versus flow rate data and efficiency versus flow rate data and increasing the number of data points per curve from 7 to 10 so as to get more data values throughout the range of flow rates for a particular curve.
I have been challenged in this regard by the software developer, who is a senior mechanical engineer, and who tells me a 4th order curve will describe the data perfectly. He holds the position that a 4th order curve will fit irregularities in the actual performance of the pump that my university theory cannot account for and has dismissed my arguments on the grounds of inexperience in the field.
I have searched far and wide in literature for some guidance, including curve fitting techniques, correlation coefficients, residual plots etc but have not found anything worthwhile yet. I would appreciate the advice of anyone who has had experience with this type of problem.
Kind Regards,
Patrick
7 flow rate values
Kind Regards,
Patrick
