Vulcanelli
Industrial
I am trying to make a closed surface from four curves. The 'intersection guide curve is made from two intersecting surfaces and should be good by default. The other two profiles called 'Wave profile inside and outside' appear to be connected to the intersecting guide curve and yet I get the error message 'The selected curve must form a closed loop' when I try create a surface from a closed boundary and SolidEdge does not show what is not closed. Anyone see anything obviously wrong? Part is made in V20. Thanks
