Curve width
niedzviedz
307
Is there any way to get the real curve width by nxopen?
Code:
DisplayableObject.linewidth
return values from 5-13 for example:
Code:
NXOpen.DisplayableObject.ObjectWidth.Six
How to convert it real value like "0,18 mm"?
With best regards
Michael
record a journal
and interactivity browse the
preferences to line width.
displayModification1.NewWidth = NXOpen.DisplayableObject.ObjectWidth.One
displayModification1.NewWidth = NXOpen.DisplayableObject.ObjectWidth.Two
displayModification1.NewWidth = NXOpen.DisplayableObject.ObjectWidth.Three
displayModification2.NewWidth = NXOpen.DisplayableObject.ObjectWidth.Four
displayModification3.NewWidth = NXOpen.DisplayableObject.ObjectWidth.Five
try something like this
' NX 11.0.0.33
' Journal created by haviv2 on Wed Oct 28 08:40:00 2020 Jerusalem Standard Time
Imports System
Imports NXOpen
Module NXJournal
Sub Main (ByVal args() As String)
Dim theSession As NXOpen.Session = NXOpen.Session.GetSession()
Dim workPart As NXOpen.Part = theSession.Parts.Work
Dim displayPart As NXOpen.Part = theSession.Parts.Display
' Menu: File->Utilities->Customer Defaults...
' Dialog Begin Customer Defaults
Dim changeList1 As NXOpen.Options.ChangeList = Nothing
changeList1 = theSession.OptionsManager.NewOptionsChangeList(NXOpen.Options.LevelType.User, NXOpen.Options.LevelLockedByDefault.False)
changeList1.SetValue("UG_lineWidth1Name", "0.1300 mm")
changeList1.Save()
changeList1.Dispose()
' Menu: Tools->Journal->Stop Recording
End Sub
End Module
sorry I think that there is no way
to reach the list of widths.
you can make your list
but that's can be changed by Siemens
In NX the objects does/does not carry the actual width in mm or Inches. ( ?)
The width in mm is mapped when printing /plotting/displaying via the defaults for that "specific Operation".
Way back in time, NX had three widths, thin, medium, Thick which had corresponding numbers something like thin = 1, medium =3 and Thick = 2 ( these numbers are from my memory and probably in the wrong order)
When you were about to plot, you placed a thin pen ( =0.18 mm) in the pen carousel of the plotter in the slot # 1, a medium pen ( = 0.35 mm) in the pen holder #3 etc
the actual widths on the plotted paper was depending on that you picked the correct pen and placed that in the correct slot in the carousel.
I would guess though that NX internally uses the current 1-9 definition and that the "mm" - mapping will occur only when needed.
Print/plot/export to pdf/export to .../ etc
Tomas
in nx exist a list og widths in mm
but it's not reachable.
Code:
On customer defaults I found this:
But lines created on file has values from 5 to 13. I'm not sure if I open file from created on different computer I will get the same values.
With best regards
Michael
The code below reports some of the line width options for the current session. I'm not sure how to interpret the conversion values...
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Dim theSession As Session = Session.GetSession()
    Dim theUfSession As UFSession = UFSession.GetUFSession()
    Dim theUI As UI = UI.GetUI()
    Dim lw As ListingWindow = theSession.ListingWindow
    Sub Main()
        Dim markId1 As Session.UndoMarkId
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "NXJ")
        lw.Open()
        Try
            ListOption("UG_lineWidth1Name")
            ListOption("UG_lineWidth2Name")
            ListOption("UG_lineWidth3Name")
            ListOption("UG_lineWidth4Name")
            ListOption("UG_lineWidth5Name")
            ListOption("UG_lineWidth6Name")
            ListOption("UG_lineWidth7Name")
            ListOption("UG_lineWidth8Name")
            ListOption("UG_lineWidth9Name")
            ListOption("UG_thinLineWidthToNewLineWidth")
            ListOption("UG_normalLineWidthToNewLineWidth")
            ListOption("UG_thickLineWidthToNewLineWidth")
            ListOption("UG_plot_custom_thin_width_name")
            ListOption("UG_plot_custom_thin_width_MU")
            ListOption("UG_plot_custom_thin_width_EU")
            ListOption("UG_plot_custom_normal_width_name")
            ListOption("UG_plot_custom_normal_width_MU")
            ListOption("UG_plot_custom_normal_width_EU")
            ListOption("UG_plot_custom_thick_width_name")
            ListOption("UG_plot_custom_thick_width_MU")
            ListOption("UG_plot_custom_thick_width_EU")
            ListOption("UG_plot_custom_width1_width_name")
            ListOption("UG_plot_custom_width1_width_MU")
            ListOption("UG_plot_custom_width1_width_EU")
            ListOption("UG_plot_custom_width2_width_name")
            ListOption("UG_plot_custom_width2_width_MU")
            ListOption("UG_plot_custom_width2_width_EU")
            ListOption("UG_plot_custom_width3_width_name")
            ListOption("UG_plot_custom_width3_width_MU")
            ListOption("UG_plot_custom_width3_width_EU")
            ListOption("UG_plot_custom_width4_width_name")
            ListOption("UG_plot_custom_width4_width_MU")
            ListOption("UG_plot_custom_width4_width_EU")
            ListOption("UG_plot_custom_width5_width_name")
            ListOption("UG_plot_custom_width5_width_MU")
            ListOption("UG_plot_custom_width5_width_EU")
            ListOption("UG_plot_custom_width6_width_name")
            ListOption("UG_plot_custom_width6_width_MU")
            ListOption("UG_plot_custom_width6_width_EU")
            ListOption("UG_plot_custom_width7_width_name")
            ListOption("UG_plot_custom_width7_width_MU")
            ListOption("UG_plot_custom_width7_width_EU")
            ListOption("UG_plot_custom_width8_width_name")
            ListOption("UG_plot_custom_width8_width_MU")
            ListOption("UG_plot_custom_width8_width_EU")
            ListOption("UG_plot_custom_width9_width_name")
            ListOption("UG_plot_custom_width9_width_MU")
            ListOption("UG_plot_custom_width9_width_EU")
            ListOption("UG_widthDisplay")
            ListOption("UG_widthSizingMethod")
            ListOption("UG_widthScale")
            ListOption("UG_pixelWidth1")
            ListOption("UG_pixelWidth2")
            ListOption("UG_pixelWidth3")
            ListOption("UG_pixelWidth4")
            ListOption("UG_pixelWidth5")
            ListOption("UG_pixelWidth6")
            ListOption("UG_pixelWidth7")
            ListOption("UG_pixelWidth8")
            ListOption("UG_pixelWidth9")
        Catch ex As NXException
            theSession.UndoToMark(markId1, "NXJ")
            MsgBox(ex.Message)
        Finally
        End Try
        lw.Close()
    End Sub
    Sub ListOption(ByVal theOption As String)
        lw.WriteLine(theOption)
        'lw.WriteLine("value set at site level: " & theSession.OptionsManager.IsValueSet(theOption, Options.LevelType.Site).ToString)
        'lw.WriteLine("locked at site level: " & theSession.OptionsManager.IsValueLocked(theOption, Options.LevelType.Site))
        'lw.WriteLine("option type: " & theSession.OptionsManager.GetOptionType(theOption).ToString)
        Select Case theSession.OptionsManager.GetOptionType(theOption)
            Case Is = Options.OptionType.String
                lw.WriteLine("site level value: " & theSession.OptionsManager.GetStringValue(theOption, Options.LevelType.Site))
            Case Is = Options.OptionType.Int
                lw.WriteLine("site level value: " & theSession.OptionsManager.GetIntValue(theOption, Options.LevelType.Site))
            Case Is = Options.OptionType.Real
                lw.WriteLine("site level value: " & theSession.OptionsManager.GetRealValue(theOption, Options.LevelType.Site))
            Case Is = Options.OptionType.Logical
                lw.WriteLine("site level value: " & theSession.OptionsManager.GetLogicalValue(theOption, Options.LevelType.Site))
            Case Else
                'skip other types for now...
                lw.WriteLine("option type not accounted for: " & theSession.OptionsManager.GetOptionType(theOption).ToString)
        End Select
        lw.WriteLine("")
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image immediately after execution within NX
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
www.nxjournaling.com
What is the purpose of the original question ?
Mathematically a line does not have a thickness, there is no thickness on a vector, the thickness in NX is assigned for the only purpose of display and plotting.
thereby the thickness can be added "late in the process", i.e when displaying the computed object or printing.
Tomas
@Cowski thank for the code. I will check it and write some review after that.
@Toost I know that Line, point or surface has no thickness, but in NX You can set width for representation. I writing journal to show selected curve properties like color, layer, type (solid, centreline, dotted) and width, because sometimes when I open documentation from different company or when I create for example symbolic thread on part and go to assembly, the lines are thick. I know I can use edit object display to check it and correct it, but I wanna do It faster but journal.
Right now I only have values for example DisplayableObject.ObjectWidth.Five, but in edit object display I get 0,13 mm.
With best regards
Michael
Hello everybody,
@cowski thank for Your code, it help me alot.
Finally I found some time to finish it. I figure it out:
Code:
.linewidth
show values from 5-13, but
Code:
needs values from 1-9 or thick, thin and normal.
Below is my code. Maybe it will be usefull to someone.
Code:
Option Strict Off
Imports System
Imports System.Windows.Forms
Imports System.Drawing
Imports NXOpen
Imports NXOpen.UF
Module Module1
	Dim red As Integer
	Dim green As Integer
	Dim blue As Integer
	Dim ColorNo as String
	Dim ColorName as String
	Dim LW1 as String
	Dim LW2 as String
	Dim LW3 as String
	Dim LW4 as String
	Dim LW5 as String
	Dim LW6 as String
	Dim LW7 as String
	Dim LW8 as String
	Dim LW9 as String
Sub Main()
	Dim theUFSession As UFSession = UFSession.GetUFSession
	Dim myObj As NXObject
	Dim myDispObj As DisplayableObject
	Dim myForm1 As New Form1
	Dim MyFont as String
	Dim MyWidth as String
	LW1 = theSession.OptionsManager.GetStringValue("UG_lineWidth1Name", Options.LevelType.Site)
	LW2 = theSession.OptionsManager.GetStringValue("UG_lineWidth2Name", Options.LevelType.Site)
	LW3 = theSession.OptionsManager.GetStringValue("UG_lineWidth3Name", Options.LevelType.Site)
	LW4 = theSession.OptionsManager.GetStringValue("UG_lineWidth4Name", Options.LevelType.Site)
	LW5 = theSession.OptionsManager.GetStringValue("UG_lineWidth5Name", Options.LevelType.Site)
	LW6 = theSession.OptionsManager.GetStringValue("UG_lineWidth6Name", Options.LevelType.Site)
	LW7 = theSession.OptionsManager.GetStringValue("UG_lineWidth7Name", Options.LevelType.Site)
	LW8 = theSession.OptionsManager.GetStringValue("UG_lineWidth8Name", Options.LevelType.Site)
	LW9 = theSession.OptionsManager.GetStringValue("UG_lineWidth9Name", Options.LevelType.Site)
	'lw.open
	'lw.writeline("1: " & lw1)
	'lw.writeline("2: " & lw2)
	'lw.writeline("3: " & lw3)
	'lw.writeline("4: " & lw4)
	'lw.writeline("5: " & lw5)
	'lw.writeline("6: " & lw6)
	'lw.writeline("7: " & lw7)
	'lw.writeline("8: " & lw8)
	'lw.writeline("9: " & lw9)
	'exit sub
	Do Until SelectAnObject(myObj) = Selection.Response.Cancel
		myDispObj = DirectCast(myObj, DisplayableObject)
		ColorNo = myDispObj.Color
		Dim myColor As NXColor
		Myfont = myDispObj.linefont
		MyWidth = myDispObj.linewidth
		'MyWidth = myDispObj.ObjectWidth
		'lw.writeline(MyWidth)
		myColor = theSession.Parts.Work.Colors.Find(myDispObj.Color)
		ColorNAme = myColor.Label
		Dim red As Integer = myColor.GetRgb.R * 255
		Dim green As Integer = myColor.GetRgb.G * 255
		Dim blue As Integer = myColor.GetRgb.B * 255
		myform1.ColorNo = ColorNo
		myform1.ColorName = ColorName
		myform1.Red = Red
		myform1.Green = Green
		myform1.Blue = Blue
		myForm1.MyFont = MyFont
		myform1.MyWidth = MyWidth
		myform1.LW1 = LW1
		myform1.LW2 = LW2
		myform1.LW3 = LW3
		myform1.LW4 = LW4
		myform1.LW5 = LW5
		myform1.LW6 = LW6
		myform1.LW7 = LW7
		myform1.LW8 = LW8
		myform1.LW9 = LW9
		myForm1.ShowDialog()
		If myForm1.Canceled Then
			'Exit sub
			Return
		Else
		End If
	Loop
	'lw.close
End Sub
Function SelectAnObject(ByRef selObj As NXObject) As Selection.Response
	Dim prompt As String = "Choose a curve:"
	Dim cursor As Point3d
	Dim typeArray() As Selection.SelectionType = {Selection.SelectionType.Curves}
	Dim resp As Selection.Response = theUI.SelectionManager.SelectObject( _
		prompt, "Choose a curve", _
		Selection.SelectionScope.AnyInAssembly, _
		False, typeArray, selObj, cursor)
	If resp = Selection.Response.ObjectSelected Or _
		resp = Selection.Response.ObjectSelectedByName Then
		Return Selection.Response.Ok
	Else
		Return Selection.Response.Cancel
	End If
End Function
	'Unloads the image when the NX session terminates
	GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
End Function
End Module
Public Class Form1
	Public Red As Integer
	Public Green As Integer
	Public Blue As Integer
	Public ColorNo as String
	Public ColorName as String
	Public MyFont as String
	Public MyWidth as Integer
    Public LW1, LW2, LW3, LW4, LW5, LW6, LW7, LW8, LW9 as String
Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
	Me.Close()
End Sub
Private Sub Button3_Click(sender As Object, e As EventArgs) Handles Button3.Click
	_canceled = True
	Me.Close()
End Sub
Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load
    For Each c As Control In Controls
        AddHandler c.MouseClick, AddressOf ClickHandler
    Next
	Label4.Text = ""
	Label5.Text = ""
	Label7.Text = ""
	Label10.Text = ""
	Label11.Text = ""
	colorchange()
End Sub
Private Sub colorchange()
	Label4.Text = ColorNo
	Label5.Text = ColorName
	Label7.Text = Red & ", " & Green & ", " & Blue
	If MyFont = "1" then
		Label10.Text = "Solid"
	elseif 	MyFont = "2" then
		Label10.Text = "Dashed"
	elseif 	MyFont = "3" then
		Label10.Text = "Phantom"
	elseif 	MyFont = "4" then
		Label10.Text = "Centerline"
	elseif 	MyFont = "5" then
		Label10.Text = "Dotted"
	elseif 	MyFont = "6" then
		Label10.Text = "Long Dashed"
	elseif 	MyFont = "7" then
		Label10.Text = "Dotted Dashed"
	End if
	if MyWidth = 5 then
		Label11.Text = LW1
	elseif MyWidth = 6 then
		Label11.Text = LW2
	elseif MyWidth = 7 then
		Label11.Text = LW3
	elseif MyWidth = 8 then
		Label11.Text = LW4
	elseif MyWidth = 9 then
		Label11.Text = LW5
	elseif MyWidth = 10 then
		Label11.Text = LW6
	elseif MyWidth = 11 then
		Label11.Text = LW7
	elseif MyWidth = 12 then
		Label11.Text = LW8
	elseif MyWidth = 13 then
		Label11.Text = LW9
	end if
	Button2.BackColor = Color.FromArgb(255, Red, Green, Blue)
End Sub
Private Sub ClickHandler(sender As Object, e As MouseEventArgs) Handles Me.MouseClick
	'Label1.Text = String.Format("{0}", e.Button.ToString.ToLower)
   if e.Button = MouseButtons.Middle then
		'Label2.Text = "Middle"
		SendKeys.Send("{ENTER}")
	end if
End Sub
Private _canceled As Boolean = False
Public ReadOnly Property Canceled() As Boolean
	Get
		Return _canceled
	End Get
End Property
End Class
<Global.Microsoft.VisualBasic.CompilerServices.DesignerGenerated()> _
Partial Class Form1
Inherits System.Windows.Forms.Form
<System.Diagnostics.DebuggerNonUserCode()> _
Protected Overrides Sub Dispose(ByVal disposing As Boolean)
	Try
		If disposing AndAlso components IsNot Nothing Then
			components.Dispose()
		End If
		Finally
			MyBase.Dispose(disposing)
	End Try
End Sub
Protected Overrides ReadOnly Property CreateParams() As System.Windows.Forms.CreateParams
	Get
		Dim param As System.Windows.Forms.CreateParams = MyBase.CreateParams
		param.ClassStyle = param.ClassStyle Or &H200
		Return param
	End Get
End Property
Private components As System.ComponentModel.IContainer
<System.Diagnostics.DebuggerStepThrough()> _
Private Sub InitializeComponent()
	Me.Label1 = New System.Windows.Forms.Label()
	Me.Label2 = New System.Windows.Forms.Label()
	Me.Label3 = New System.Windows.Forms.Label()
	Me.Label4 = New System.Windows.Forms.Label()
	Me.Label5 = New System.Windows.Forms.Label()
	Me.Label6 = New System.Windows.Forms.Label()
	Me.Label7 = New System.Windows.Forms.Label()
	Me.Label8 = New System.Windows.Forms.Label()
	Me.Label9 = New System.Windows.Forms.Label()
	Me.Label10 = New System.Windows.Forms.Label()
	Me.Label11 = New System.Windows.Forms.Label()
	Me.Button1 = New System.Windows.Forms.Button()
	Me.Button2 = New System.Windows.Forms.Button()
	Me.Button3 = New System.Windows.Forms.Button()
	Me.SuspendLayout()
	'Label1
	Me.Label1.AutoSize = True
	Me.Label1.Location = New System.Drawing.Point(10, 10)
	Me.Label1.Name = "Label1"
	Me.Label1.Size = New System.Drawing.Size(134, 25)
	Me.Label1.TabIndex = 0
	Me.Label1.Text = "Color Number:"
	'Label2
	Me.Label2.AutoSize = True
	Me.Label2.Location = New System.Drawing.Point(10, 38)
	Me.Label2.Name = "Label2"
	Me.Label2.Size = New System.Drawing.Size(136, 25)
	Me.Label2.TabIndex = 0
	Me.Label2.Text = "Color name:"
	'Label3
	Me.Label3.AutoSize = True
	Me.Label3.Location = New System.Drawing.Point(10, 66)
	Me.Label3.Name = "Label3"
	Me.Label3.Size = New System.Drawing.Size(64, 25)
	Me.Label3.TabIndex = 0
	Me.Label3.Text = "Color:"
	'Label4
	Me.Label4.AutoSize = True
	Me.Label4.Location = New System.Drawing.Point(110, 10)
	Me.Label4.Name = "Label4"
	Me.Label4.Size = New System.Drawing.Size(45, 25)
	Me.Label4.TabIndex = 0
	Me.Label4.Text = ""
	'Label5
	Me.Label5.AutoSize = True
	Me.Label5.Location = New System.Drawing.Point(110, 38)
	Me.Label5.Name = "Label5"
	Me.Label5.Size = New System.Drawing.Size(40, 25)
	Me.Label5.TabIndex = 0
	Me.Label5.Text = ""
	'Label6
	Me.Label6.AutoSize = True
	Me.Label6.Location = New System.Drawing.Point(10, 94)
	Me.Label6.Name = "Label6"
	Me.Label6.Size = New System.Drawing.Size(40, 25)
	Me.Label6.TabIndex = 0
	Me.Label6.Text = "RGB:"
	'Label7
	Me.Label7.AutoSize = True
	Me.Label7.Location = New System.Drawing.Point(110, 94)
	Me.Label7.Name = "Label7"
	Me.Label7.Size = New System.Drawing.Size(40, 25)
	Me.Label7.TabIndex = 0
	Me.Label7.Text = ""
	'Label8
	Me.Label8.AutoSize = True
	Me.Label8.Location = New System.Drawing.Point(10, 122)
	Me.Label8.Name = "Label8"
	Me.Label8.Size = New System.Drawing.Size(40, 25)
	Me.Label8.TabIndex = 0
	Me.Label8.Text = "Type:"
	'Label9
	Me.Label9.AutoSize = True
	Me.Label9.Location = New System.Drawing.Point(10, 150)
	Me.Label9.Name = "Label9"
	Me.Label9.Size = New System.Drawing.Size(40, 25)
	Me.Label9.TabIndex = 0
	Me.Label9.Text = "Thickness:"
	'Label10
	Me.Label10.AutoSize = True
	Me.Label10.Location = New System.Drawing.Point(110, 122)
	Me.Label10.Name = "Label10"
	Me.Label10.Size = New System.Drawing.Size(40, 25)
	Me.Label10.TabIndex = 0
	Me.Label10.Text = ""
	'Label11
	Me.Label11.AutoSize = True
	Me.Label11.Location = New System.Drawing.Point(110, 150)
	Me.Label11.Name = "Label11"
	Me.Label11.Size = New System.Drawing.Size(40, 25)
	Me.Label11.TabIndex = 0
	Me.Label11.Text = ""
	'Button1
	Me.Button1.Location = New System.Drawing.Point(20, 176)
	Me.Button1.Name = "Button1"
	Me.Button1.Size = New System.Drawing.Size(80, 22)
	Me.Button1.TabIndex = 2
	Me.Button1.Text = "Next"
	Me.Button1.UseVisualStyleBackColor = True
	'Button2
	Me.Button2.Location = New System.Drawing.Point(110, 66)
	Me.Button2.Enabled = false
	Me.Button2.Flatstyle = FlatStyle.flat
	Me.Button2.Name = "Button2"
	Me.Button2.Size = New System.Drawing.Size(85, 20)
	Me.Button2.TabIndex = 0
	Me.Button2.UseVisualStyleBackColor = True
	'Button3
	Me.Button3.Location = New System.Drawing.Point(120, 176)
	Me.Button3.Name = "Button3"
	Me.Button3.Size = New System.Drawing.Size(80, 22)
	Me.Button3.TabIndex = 1
	Me.Button3.Text = "Cancel"
	Me.Button3.UseVisualStyleBackColor = True
	'Form1
	Me.AutoScaleDimensions = New System.Drawing.SizeF(8.0!, 16.0!)
	Me.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font
	Me.ClientSize = New System.Drawing.Size(230, 250)
	Me.Controls.Add(Me.Button3)
	Me.Controls.Add(Me.Button2)
	Me.Controls.Add(Me.Button1)
	Me.Controls.Add(Me.Label11)
	Me.Controls.Add(Me.Label10)
	Me.Controls.Add(Me.Label9)
	Me.Controls.Add(Me.Label8)
	Me.Controls.Add(Me.Label7)
	Me.Controls.Add(Me.Label6)
	Me.Controls.Add(Me.Label5)
	Me.Controls.Add(Me.Label4)
	Me.Controls.Add(Me.Label3)
	Me.Controls.Add(Me.Label2)
	Me.Controls.Add(Me.Label1)
	Me.AcceptButton = Button1
	Me.CancelButton = Button3
	Me.Font = New System.Drawing.Font("Microsoft Sans Serif", 9.75!, System.Drawing.FontStyle.Regular, System.Drawing.GraphicsUnit.Point, CType(238, Byte))
	Me.FormBorderStyle = System.Windows.Forms.FormBorderStyle.Sizable
	Me.MaximumSize = New System.Drawing.Size(230, 250)
	Me.MinimumSize = New System.Drawing.Size(230, 250)
	Me.MaximizeBox = False
	Me.MinimizeBox = False
	Me.Name = "Form1"
	Me.StartPosition = System.Windows.Forms.FormStartPosition.CenterScreen
	Me.Text = "Curve Color"
	Me.ResumeLayout(False)
	Me.PerformLayout()
End Sub
	Friend WithEvents Label1 As Label
	Friend WithEvents Label2 As Label
	Friend WithEvents Label3 As Label
	Friend WithEvents Label4 As Label
	Friend WithEvents Label5 As Label
	Friend WithEvents Label6 As Label
	Friend WithEvents Label7 As Label
	Friend WithEvents Label8 As Label
	Friend WithEvents Label9 As Label
	Friend WithEvents Label10 As Label
	Friend WithEvents Label11 As Label
	Friend WithEvents Button1 As Button
	Friend WithEvents Button2 As Button
	Friend WithEvents Button3 As Button
End Class
With best regards
Michael
