curved washer 1
hotiron
79
0
0
Hi all
I can wrap geometry onto a curved surface or extrusion. How can I cut and leave the wrapped sketch?
The wrapped sketch isn't actually created when used in a Deboss or Emboss feature. If you want a representation of the wrapped sketch, try using the Scribe option.
If you explain what you are trying to achieve, we may be able to give a better answer.
[cheers]
CBL
I am trying to model basically a curved or bowed washer. (a flat washer formed into an arc to act as a spring) Ive extruded the partial arc and were trying to use warap to get the form I need, but cannot trim sections outside of the form.
CBL
I'll have to play with it as I dont use sheet metal tools much. Ill research what I can and any tips would be great.
