My install path is non standard I think out of the Box it wants to go somewhere like.
C:\Program files\ugs\NX-3\UGII
With these paths here a tip. Don't leave any spaces in the directory names that you chose to use. Otherwise some utilities and translators occasionally struggle.
I just take a backup of the original by copying and renaming it to something like "ug_env_original.dat". then I go ahead and edit the file.
The better way to go is to script the variables in a start-up batch file and start NX from that.
Don't do that yet though better to change one thing at a time just get your patterns working first.
OK. I think I located file but it's actually ugii_env.dat, not ug_env.dat. That's why my search couldn't find it.
Now that we've located that, it seems I have have two undesirable choices: (1) Place my pattern files in the UGII directory of every user, which will rob me of the ability to change all patterns/drawing formats by changing one file. I will have to go into every user's UGII directory and replace/edit their respective pattern files. (2) Redirect the pattern file location in every user's ugii_env.dat file to a common location on the network. While I will be able to change a pattern/drawing format by modifying only one file, I may experience complications when updating UG.
If I have my facts straight it seems that option 2 may be the lesser of the two evils. I'll basically have to go into ugii_env.dat and point it at the desired pattern directory on the network when we update.
Speaking of updating, does anyone know if GM is completely up on NX5? I'm a little cut-off from the mainstream.
Our site is setup using a customized custom_env.dat file (note: file name does not matter) located on our network system. In this file place any variables that you want have point to any site customizations you need. For example the UGII_PATDIR variable.
The only requirement to using this method is the last entry at the end of the custom_env.dat file. It must read exactly as shown below:
# last line reads the standard ugii_env.dat file located on each users machine
# the line needs the pound sign in front to work
#include ${UGII_ROOT_DIR}\ugii_env.dat
The first 2 lines are comments for reminders to the command. The last line then reads the ugii_env.dat on each users machine. What ever variables defined in the custom_env.dat file take precidence over what is defined in the ugii_env.dat file.
Now, on each users machine make the following modifications:
1. Mapped a drive to access the folder containing your customizations. For example: V:.
2. Modify the system variable UGII_ENV_FILE variable to point to the custom_env.dat file. Example: UGII_ENV_FILE=V:\custom_env.dat
Now you can make global site changes that all users see when the software starts.
One other advantage to using this method, when you upgrade to the next version of NX, your customizations carry forward and do not have to be redefined.
I'd advise that when you do upgrade to the next version of NX that you very carefully check the out of the box ugii_env.dat file since new variables are introduced for new or changing modules and old ones are retired from time to time. It is always better to give it a thorough going over before you start working with the data.
Yes, but it's not as direct. There is an Expression function which will extract the current date and time and from there you can pass the results to an Attribute which can be referenced by a note embedded in your drawing template.
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
Ostensibly this option was designed to be used to manually force NX to synchronize a part file's attributes with those it shares with TeamCenter. However, even if you don't have TeamCenter this usually forces the attributes to update anyway. Give it a try and see if that helps.
John R. Baker, P.E.
NX Design
Cypress, CA
I have trouble showing a pattern in a sheet. This is odd as I've already tried this several weeks ago without any problems at all. I can't figure out what I'm doing different.
This is what I do:
- New File
- In Modeling: use basic curves to draw borders and title block
- Settings: File > Options > Save Options > Pattern Data Only
- Save file
- New File
- In Drafting: Format > Pattern > Retrieve Pattern
(sheet now has borders and a table)
- Save File
- Find file 'ugii_env.dat'
- Change line '#UGII_PATDIR=' to 'UGII_PATDIR=H:\Temp\MyPatterns'
- Restart NX
But when I open the file that should contain the pattern, I only find an outline of the pattern. I do not find the curves that I've drawn myself.
Any help is greatly appreciated.
(There's one thing I noticed several weeks ago and that is that when I reverted the edit in ugii_env.dat that the pattern could still be found. I'm not sure if this has something to do with it, but I thought it was odd.)
I still don't know why the pattern does not show up. But apart from that, now I have another problem -> I can not use text in modeling as I can in drafting. So I can not save the text attributes in the part/pattern.
I'm feeling not getting anywhere. What actually is the way of working for this?
When I did our title blocks I created them in Drafting mode, then exported them as CGM files. I then imported the CGM files into new parts in Modeling. The text will come in as geometry, and can be saved with the pattern. Remember that the 'text' is not really text, and won't be editable, so don't include anything that you'll want to change once the pattern is in a drawing. I did our editable text as separate parts that are imported into the drawing after the pattern is brought in.
If you mean whether making changes to the pattern will propagate automatically to drawings, it should. I have made several changes to our patterns, as we're still dialing everything in, and was surprised to see that the drawings reflect these changes.
@Mike14 Oct 08 11:36
You're right about the pattern propagation. And you're right about the text import. But then a new worm pops up. The automatic text that John was talking about (4 Oct 08 20:06) doesn't update if it is retrieved from pattern.
I'm a bit confused that this is so difficult. A pattern is not too useful without automatic text.
@myself 12 Oct 08 7:11
I found out that I did not need to change the ugii_env.dat file. Also changing load from folders does not do much here. Sometimes the pattern sticks after a save and sometimes it doesn't. Very erratic.
