jakeatberkshire
Industrial
- Sep 6, 2011
- 4
Hi All,
I work at an aerospace manufacturing facility using NX6. We specialize in hydraulic distribution manifolds for a variety of applications. Many of our parts include industry standard ports and hole types. We have grip files set up and use custom software to guide the modeling of these features along with the associated tooling. However, when drafting the models this information is input manually. Naturally, this is not an ideal solution. It takes significantly longer to draft and leaves room for user error. Incorrect dimensions can be added and it requires the user to confirm in modeling that the correct dimensions are actually there.
I'm trying to address this issue and was looking for suggestions from the community here. We use Feature Parameters to pull dimensions for drilled, tapped, and bolt holes so I first looked there for a solution. Unfortunately, the amount of information you can pull is rather limited. I'm now looking into creating custom templates for Feature Parameters. My first question would be, do any of you have experience in creating these templates and does that seem like the right avenue to initially pursue? Ultimately, I'd like to be able to pull the chamfer diameter, reamed diameter, and drilled diameter of a feature along with the included depths of each in just a few clicks. I know this must be possible, just trying to figure the simplest and most effective way to collect data from the model.
Please let me know if anything is unclear in my explanation. Look forward to your responses.
