  • Congratulations Danlap on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Cut with surface problem 1
CMorehead
31
I can't figure out why I can't use Surface Offset 8 so that I can use Cut With Surface. When I try this I get an error message. The part can be found here.
I remove the check mark from Auto Select and manually select the 14 solid bodies. The error message I get is Operation Failed Due To Geometric Condition. I don't find this message to be very helpful.
You need to extend the surface seen in the left view so that it extends past the solid bodies.
[cheers]
