enginesrus
- Aug 30, 2003
- 1,017
Like the crankshaft snout that has no keyway cut into it, and requires a nice tight bolt to push on the harmonic balancer to keep the timing gear from rotating and throwing the valve actuating system out of time.
And best of all the bolt has a right hand thread (clock wise to tighten) and that end of the crankshaft turns the same direction, so you have not only dynamic movement from engine and firing pulses, but also any belt driven accessories like alternator, power steering pump and what ever else is belt driven tending to loosen that bolt. I personally don't think you would ever find such idiocy on an aircraft.
