clarke1973
- Apr 21, 2014
- 70
I need to create an opening in an existing concrete roof structure, which consists of 5m long 250mm thick precast hollow core slabs spanning onto precast concrete beams.
obviously we cannot cut through the pre-stressed slabs, so we are proposing to cut and remove the full slab units (3 no. x 1.2m wide), add some steel trimmer beams to frame out the opening and add some new shorter span HCS spanning onto the steel beams.
can anyone offer some guidance on this? We are proposing to cut along the interface of the HCS slabs with the supporting RC beam (i.e where the top part of the beam was cast insitu with the HCS screed). Assuming the HCS is not bonded with the beam surface (supported on a form of bearing pad), the units should be able to be lifted straight off, once cut...? (in theory anyway)
Does anyone have any experience with this who can offer some advice?
Also, is it possible to fix a lifting eye to the slabs for cranage (assuming the strands can be located, and avoided)?
Thanks in advance
Thanks in advance
