Daft Question About Parameters
Simes
Automotive
Feb 13, 2017
7
Hello!
Once I've made a parameter and re-named it, is there any way of viewing the parameter type, or editing the parameter type?
Thanks all
Simon
don't think you can change the type
Eric N.
That's annoying. Found out how to check what they are though- just go parameters and filter the view by parameter type.
Thanks for your help
@Simes
You can't change the parameter type after creation. It's set in stone. Your best approach would be to create the new parameter of the correct type and use the "Replace" command to swap it in for the previous parameter and have all of the links update.
Drew Mumaw
