simar187
- Dec 30, 2007
- 19
I am planning on performing an AIR leakage test on a butterfly style damper intended for GAS service. My plan is to fasten blind flanges to both sides of the damper. One blind flange will have an air connection to connect to a air compressor. The other blind flange will have a flow meter connected to it to measure the air leakage. The leakage test will be performed while the damper is in the closed position and the test pressure range is between 0.5 psi to 5 psi.
I was hoping that someone could enlighten me as to whether this was a reasonable approach, or whether there are better, alternative methods to testing for air leakage. I was also concerned as to whether this setup may present any safety issues.
