Hello Everyone,
I have been a little problem to solve and I could do with some input.
I need to trend a vacuum pressure level inside a tank at approximately 10Hz (every 0.1s). I was going to go with a Allen Bradley PLC and a sensor with an analogue output of 4-20mA or 0-10volt but the budget is not there for this as its a new company and they haven't budgeted for the initial software cost. This is only for R&D so I can choose any hardware I like as long as the cost is reasonable.
I was looking at a sensor like this to use "SPT25-20-V30D PRESS XMTR -14.7 TO 30 PSI 4-20mA 1/4in MNPT DIN L-CONN" from Automation Direct
Then try and use one of these data loggers from Pico Tech.
Ideally the data can be manipulated in excel but if not as long as it can bring up a nice graph would be good. Has anybody any other ideas?
Thanks Trevor
Thanks Trevor
