Looking for a resource that gives maximum pressure data under constant volume conditions for the following common fuels:
C8H18
C12H23
Basically I would like to compare the results of our experiment to previously published studies. We start with a spherical constant volume chamber "bomb" and add a stoichiometric mixture of fuel @ different compression ratios (bar)and mass to find the maximum pressure of combustion in a constant volume container. Any studies out there that give basic maximum pressure values for these two fuels @ varying charge mass and compression ratios?
Should be simple stuff to find but I am not coming up with easy data for it. Thanks,
Randy
C8H18
C12H23
Randy
