Datum as plane tangent to two cylindrical surfaces 2
tw_0407
I have a part with two partial cylindrical surfaces and I want to make a datum that is the plane tangent to the two surfaces, as the mating part has a flat surface that is seated up against them.
Part is similar to this example I mocked up:
And I want the datum to be tangent to both surfaces, like so:
Can I just sketch a line between them on a top-down view like in the above picture, and attach a datum to that?
"The reasoning for the targets in 7-58 is they are separate parts of a single datum which do not form a plane as opposed to being multiple contacts forming a single datum plane"
Multiple contacts forming a single datum plane could as well describe a datum targets application such as datum feature A in figure 7-60 (3 coplanar datum target areas). So that is hardly a criterion for the choice between the two types of datum feature designating symbols.
A much more likely criterion is: defined local contacts for datum targets vs. the entire surface/surfaces of a particular datum feature potentially intended to make contact with the simulator of the datum when the datum feature symbol is used without datum targets.
