I have a customer with a plastic injection part design, similar in size and shape to that of a scotch magic tape dispenser, but with more bosses, ribs, and holes. This is a key component in a larger assembly.
They state tolerancing is per ISO 8015:2011 and ISO GPS. They have 7 different datums, 5 of them are axis of 5 different cylinders randomly located throughout the part (not a pattern). Datum A is the large flat surface, which makes sense to me for this component. The 5 different cylinders with datums are perpendicular to datum A, however, all degrees of freedom can be eliminated with datum A and the first 2 axis datums they identified. The customer explained to me that they added the additional axis datums in order for features referencing them (and closest by design) to have a better chance to meet position tolerances. This would involve numerous setups for inspection based on the feature control frame requirements.
My experience is typically with 3 maybe 4 datums, on smaller less complex injection molded parts.
Is it common practice to do this, almost treat the various areas of the part as independent from the other areas?
I don't see anything in the ASME standard that doesn't support this, so my assumption is ISO is ok too.
I did warn them that they may miss knowing what the correlation is between all features using just 1 datum simulator setup. I also suggested they consider 2 datum planes that run through the "middle" along X and Y. Any thoughts or suggestions would be appreciated.
