Tapered Datums
AMontembeault
31
Y14.5 specifies the use of a conical taper as a datum candidate, arresting 5 degrees of freedom - 3 translational, 2 rotational. It makes me wonder, why couldn't the same apply to a wedge shaped, extruded feature - a dovetail, for example. Such a feature would also constrain 5 degrees of freedom, 2 translational, 3 rotational. Y14.5 doesn't explicitly call out such a feature, so I'm left questioning if this is indeed applicable as a logical extension that's just overlooked in the standard, or if I'm missing something that makes this impossible.
Good question. And it brought out past issues as you stated. I will defer on this as far as the merits of ASME. But when it was difficult to measure a taper, but it was normally a gage point. I would draw in cad the actual geometry. And calculate the theoretical sharp internal or external edges or internal corners. And add a reference dimension or diameter. While this doesn't answer your question directly. Point is I would do work a rounds. As you stated conical I normally would design a gage with sharp corners for internal or use spherical ball that would contact at the exact
Gage point.
It is the same type of datum feature as "Linear Extruded Shape". Look that up in your copy of Y14.5.
