DC Motor Help
Ballantyne888
Petroleum
I was wondering if anyone could help me figure out where to find specs of a motor with very little markings. The 12v DC motor comes out of a 5 Oceans 4" in-line blower. I cannot find any specs on it and the company has not returned my emails or calls. The only marks on the motor say "S-60933E157". I've searched everywhere I can think with no results. So I turn to you, any help would be greatly appreciated. Thank you.
Is it a replacement you need? Does the original motor work? Or do you need the data for some other purpose?
There are different approaches depending on what the answer is.
Gunnar Englund
The original motor works great. For my R&D application it is the best fan I have found, so I am trying to find the same motor but as a AC unit instead of DC. If nothing else, a very close match. So I was hoping that the "S-60933E157" would tell someone (more knowledgable than myself) some information about the motor or at least where to find the specs.
There can be a world of difference between an AC motor and a DC motor. It is not just as easy as selecting the "AC" option. You may be better off trying a few AC motors to see how they work.
You could of course use the DC motor you like, fed from AC via a bridge rectifier and optional big smoothing capacitor.
@7anoter4 yes, that is the blower. @logbook ok I will start trying that. I wasn't sure if it would be a better starting place to have the HP and RPM of the motor. Thanks everyone for your help.
