Thomas2121
I have this 12m long rafter supporting light weight roof (2m span) on one side and terrace on the other. The max deflection of the rafter is 36mm under live load, which passes the limit check for the rafter itself.
However, if I look at the 2m long purlins of the roof that span from wall to the mid span of rafter. The deflection of the purlin will be 0 at one end (wall) and 36mm at another, which is L/55. Is this acceptable? Will it cause water leaking issue and the like or am I overthinking?
